[mapguide-users] Opensource C# mwf reader
Carl Von Stetten
vonner.lists at vonner.net
Thu May 31 12:49:43 PDT 2012
Ali,
Like Jackie, I'm assuming you are referring to the AutoDesk MapGuide 6.5
product that is now discontinued.
Do you have access to a copy of MapGuide Author? If so, you can save
the MWF as an MWX file, which is an XML file. Then you can read the XML
version into whatever platform you need. You can make changes to the
MWX file also, but you will need to open in in MapGuide Author and save
it back to MWF format before MapGuide Server can use it.
HTH,
Carl Von Stetten
On 5/31/2012 8:46 AM, Ali Ahmadi wrote:
> Hi all
> i have a mwf file and need to use it in C#
> is there any component or opensource code to do that?
> thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120531/574aa60e/attachment.html>
