[mapguide-users] Opensource C# mwf reader
Ali Ahmadi aliahmadi1367 at gmail.com
Thu May 31 12:52:47 PDT 2012
thanks
my friend has made a program which shows mwf file with c#
i wonder if i could find out which component he uses for showing GIS map
thanks
On Fri, Jun 1, 2012 at 12:19 AM, Carl Von Stetten
<vonner.lists at vonner.net>wrote:
>  Ali,
> Like Jackie, I'm assuming you are referring to the AutoDesk MapGuide 6.5
> product that is now discontinued.
> Do you have access to a copy of MapGuide Author?  If so, you can save the
> MWF as an MWX file, which is an XML file.  Then you can read the XML
> version into whatever platform you need.  You can make changes to the MWX
> file also, but you will need to open in in MapGuide Author and save it back
> to MWF format before MapGuide Server can use it.
> HTH,
> Carl Von Stetten
> On 5/31/2012 8:46 AM, Ali Ahmadi wrote:
> Hi all
> i have a mwf file and need to use it in C#
> is there any component or opensource code to do that?
> thanks
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120601/46970593/attachment.html>
