[mapguide-users] Error on insert features into SQL Server Spatial
Jackie Ng jumpinjackie at gmail.com
Thu Nov 1 04:05:27 PDT 2012
It's actually both MapGuide and FDO related. There's 2 problems here:
 1. There's definitely a bug in the SQL Server FDO provider. The insert
command (transactional or not) actually succeeds, but it blows up trying to
get the class definition from the feature reader that is returned by
FdoIInsert::Execute(). The Execute() call itself doesn't throw an exception.
If you did this code with raw FDO, I'm certain you'll get the same result.
 2. If transactions are involved, it's even worse. Transaction rollback
doesn't even happen, the active transaction is left dangling due to faulty
exception handling! I made a ticket for this
(http://trac.osgeo.org/mapguide/ticket/2165). The fix for this is simple.
So file the FDO bug, as that's the root problem. Fixing problem #2 doesn't
solve problem #1
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-on-insert-features-into-SQL-Server-Spatial-tp4987600p5013278.html
