[mapguide-users] Fusion broken.
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Nov 14 08:46:08 PST 2012
So I finally got MapGuide 2.4.0 PHP on IIS7 installed and working. The
MapGuide admin page seems to work, but when I go to the fusion demo page,
FireBug gives me this error:
And the map just sits there loading indefinitely:
Fusion Error: WARNING: Exception occurred in AJAX callback. Message:
JSON.parse: unexpected character Location:
http://wppgeog3/mapguide/fusion/lib/fusion.js (786) Response: ERROR:
Resource was not found:
Library://Samples/Sheboygan/MapsTiled/SheboyganSphericalMerc.MapDefinition
- MgResourceServiceHandler.ProcessOperation() line 80 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpGetResourceContent.Execute() line 120 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\OpGetResourceContent.cpp -
MgServerResourceService.GetResourceContent() line 1222 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgApplicationRepositoryManager.GetResourceContent() line 385 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
- MgResourceDefinitionManager.GetResource
(MgLibraryResourceContents.dbxml)() line 320 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
- MgResourceContentManager.GetDocument() line 590 file
c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceDefinitionManager.GetDocument
(MgLibraryResourceContents.dbxml)() line 476 file
- MgResourceDefinitionManager.GetDocument() line 467 file
After that there are a few 407, proxy authentication failures too.
Any thoughts as to what's going on?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121114/c2b6c2df/attachment.html>
