[mapguide-users] .NET SDF Loader
Zac Spitzer
zac.spitzer at gmail.com
Wed Nov 14 22:49:07 PST 2012
created via the mapguide administrator, aliases allow you to define a
folder which
you can then simply drop files into and then reference in feature source
On Thu, Nov 15, 2012 at 5:37 PM, <mika at digikartta.net> wrote:
> "Failing that, you should consider using aliases instead"
> Could you put this other way, I have problems understanding what you are
> saying.
> Does it make difference, which version of Maestro?
> Thanks,
> - mika -
> On Wed, 14 Nov 2012 18:22:59 -0800 (PST), Jackie Ng <
> jumpinjackie at gmail.com> wrote:
>> If you are just trying to *load* these SDF files, and not do things like
>> conversion/generalization then Maestro should be able to execute your
>> existing Load Procedures as-is.
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.n6.**nabble.com/NET-SDF-Loader-**
>> tp5016355p5016459.html<http://osgeo-org.1560.n6.nabble.com/NET-SDF-Loader-tp5016355p5016459.html>
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> ______________________________**_________________
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/mapguide-**users<http://lists.osgeo.org/mailman/listinfo/mapguide-users>
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121115/0ad32ccd/attachment.html>
