[mapguide-users] Fusion broken.
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Nov 15 02:36:46 PST 2012
Hi Gabriele,
I don't know. I'm just using the default install of 2.4.0 and expected it
all to work.
Running a search, there don't appear to be any "MapDefinition" files
anywhere in the entire /MapGuide directory.
I'm surprised no samples were provided in the default install.
Looking into the documentation it's not clear how to make a MapDefinition
file (the search only finds two results which make reference to them:
http://mapguide.osgeo.org/search/node/mapdefinition), and the samples I can
find are for 2.0.x (
http://mapguide.osgeo.org/download/releases/2.0.x-samples) with the
installation notes not appearing to work with 2.4.x.
So I have to admit I've very confused as to what to do next. Is there any
current documentation somewhere? I've got it installed and MapGuide works
but I have no clue what to do next. Any suggestions?
Thanks,
Jonathan
On 14 November 2012 17:09, Gabriele Monfardini <gabrimonfa at gmail.com> wrote:
> The main error to look at seems
> "Resource was not found:
> Library://Samples/Sheboygan/MapsTiled/SheboyganSphericalMerc.MapDefinition"
> Is there this map definition?
> Regards,
> Gabriele
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121115/10a6c1b3/attachment.html>
