[mapguide-users] Demos
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Oct 1 09:36:45 PDT 2012
Hi List,
I was just looking into MapGuide and so naturally went to the "Live
Application Gallery". It seems that most of them don't actually work - I
get a lot of 404's, be they hosted at the mapguide.com domain or externally.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121001/0a5a921b/attachment.html>
