[mapguide-users] How to troubleshoot "The specified class was not found"?
Hans Milling hm at geograf.dk
Mon Oct 1 02:41:07 PDT 2012
Hi Jackie
All i get in MGOS2.4 RC2 is:
Command line output:
(4980) The specified class was not found.
error.log file:
<2012-10-01T11:36:44> 	4980	Ajax Viewer	::1	Administrator
 Error: The specified class was not found.
 StackTrace:
  - MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\mg-2.4-x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
  - MgOpQueryFeatures.Execute() line 125 file
c:\mg-2.4-x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
  - MgServerRenderingService.QueryFeatures() line 848 file
c:\mg-2.4-x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
  - MgServerRenderingService.RenderForSelection() line 1520 file
  - MgServerDescribeSchema.GetClassDefinition() line 1061 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
This is when I try selection on the map. It only happens at a certain zoom
level  so it must be some layer causing problems, but still no info on which
layer.
I will try to delete the layers one by one until the problem is gone to
identify the problematic layer.
Hans...
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-troubleshoot-The-specified-class-was-not-found-tp5005219p5005489.html
