[mapguide-users] fusion - default tool selected?
Zac Spitzer zac.spitzer at gmail.com
Mon Oct 1 19:11:24 PDT 2012
have you tried activating the pan widget in the during
fusion initialisation using javascript?
PS: please always state the software version when posting questions
On Tue, Oct 2, 2012 at 7:55 AM, elliott17 <elliottd at ae.ca> wrote:
> I am using MGOS.  I would like to see the select icon be the default icon
> when a site opens.  Currently, it is the pan command.  I edited the
> Application Definition file so that select shows up before pan under
> ContectMenu (Map) - see below.  Any help is appreciated.
>     <Container xsi:type="UiItemContainerType">
>       <Name>MapContextMenu</Name>
>       <Type>ContextMenu</Type>
>       <Item xsi:type="WidgetItemType">
>         <Function>Widget</Function>
>         <Widget>menuRefreshMap</Widget>
>       </Item>
>       <Item xsi:type="SeparatorItemType">
>         <Function>Separator</Function>
>       </Item>
>         <Widget>menuSelect</Widget>
>       </Item>
>         <Widget>menuPan</Widget>
>       </Item>
>         <Widget>menuZoomInRectangle</Widget>
>       </Item>
>       </Item>
>         <Widget>menuZoomInFixed</Widget>
>       </Item>
>         <Widget>menuZoomOutFixed</Widget>
>       </Item>
> http://osgeo-org.1560.n6.nabble.com/fusion-default-tool-selected-tp4196888p5005695.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121002/c6b4f867/attachment.html>
