[mapguide-users] 'Select Within' widget error in Fusion
keco ilona at kemeling-consulting.com
Fri Oct 12 01:52:56 PDT 2012
I added the SelectWithin widget to the toolbar from the dropdown menu
(without changing any of the settings) in the Flexible Layout resource form
in Maestro. I used the slate template from the Sheboygan mgp for my web
layout.
This is the result on my 'demo' map. If you try SelectWithin (Lochs inside
Local Authority) it gives you an error:
http://54.247.86.56/mapguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library://Map%20Setup/SW_KECO.ApplicationDefinition
I also added the widget to one of the Sheboygan examples (This is the
template I used for my demo map), also giving an error:
http://54.247.86.56/mapguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition
Many thanks for your help.
Ilona
On Fri, Oct 12, 2012 at 5:55 AM, Jackie Ng [via OSGeo.org] <
ml-node+s1560n5008192h32 at n6.nabble.com> wrote:
> We need something more precise than "I try to use the Select Within
> widget"
> What exact steps did you take? Can it be reproduced with the Sheboygan
> sample map?
> - Jackie
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Select-Within-widget-error-in-Fusion-tp5007951p5008192.html
>  To unsubscribe from 'Select Within' widget error in Fusion, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5007951&code=aWxvbmFAa2VtZWxpbmctY29uc3VsdGluZy5jb218NTAwNzk1MXwxODUxODc1Mzc1>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Ilona Kemeling
PhD, CGeog(GIS)
Mob: 07795093671
27 Ocean Drive, Edinburgh EH6 6JL
http://Kemeling-consulting.com
View this message in context: http://osgeo-org.1560.n6.nabble.com/Select-Within-widget-error-in-Fusion-tp5007951p5008235.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121012/888405d7/attachment.html>
