[mapguide-users] 'Select Within' widget error in Fusion
Jackie Ng jumpinjackie at gmail.com
Fri Oct 12 02:26:59 PDT 2012
Do you see requests made to xml2json.php? If so, if you look in the response,
does the JSON end with a semi-colon?
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Select-Within-widget-error-in-Fusion-tp5007951p5008243.html
