[mapguide-users] 'Select Within' widget error in Fusion
keco ilona at kemeling-consulting.com
Fri Oct 12 03:24:30 PDT 2012
Sorry I don't know how to find out. I looked at the log files on the
MapGuide Site Administrator and searched for information on the IIS
manager. All without any reference to xml2json.php.
I'm a newby at all things web  (but eager to learn).. Could you tell me
where to look, please?
Many thanks,
Ilona
On Fri, Oct 12, 2012 at 10:27 AM, Jackie Ng [via OSGeo.org] <
ml-node+s1560n5008243h13 at n6.nabble.com> wrote:
> Do you see requests made to xml2json.php? If so, if you look in the
> response, does the JSON end with a semi-colon?
> - Jackie
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Select-Within-widget-error-in-Fusion-tp5007951p5008243.html
>  To unsubscribe from 'Select Within' widget error in Fusion, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5007951&code=aWxvbmFAa2VtZWxpbmctY29uc3VsdGluZy5jb218NTAwNzk1MXwxODUxODc1Mzc1>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Ilona Kemeling
PhD, CGeog(GIS)
Mob: 07795093671
27 Ocean Drive, Edinburgh EH6 6JL
http://Kemeling-consulting.com
View this message in context: http://osgeo-org.1560.n6.nabble.com/Select-Within-widget-error-in-Fusion-tp5007951p5008254.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121012/323f8041/attachment.html>
