[mapguide-users] Problem with ODBC on 64-Bit-machine after Update to MG2.4 Final
Hans Milling
hm at geograf.dk
Tue Oct 16 01:31:24 PDT 2012
To use an MS Access database in a 64 bit environment you need to use a
different provider.
32-bit: Provider=Microsoft.Jet.OLEDB.4.0
64-bit: Provider=Microsoft.ACE.OLEDB.12.0
Also be sure to install this 64-bit driver:
http://www.microsoft.com/en-us/download/details.aspx?id=13255
If you have 64 bit Office 2010 or newer you do not need to install the
driver.
However if you have 32 bit M$ Office installed you need to uninstall Office
before installing this driver. You can install the 32 bit office again if
you like but I will recommend to install the 64 bit version.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-ODBC-on-64-Bit-machine-after-Update-to-MG2-4-Final-tp5008915p5008924.html
