[mapguide-users] Change map coordinate system without regenerating tiles
Zac Spitzer
zac.spitzer at gmail.com
Wed Oct 17 06:29:17 PDT 2012
rename the maps tile folder, change the map def, restore the old name
if you change anything relating to a tiled map, the cache is
automatically purged
On Wed, Oct 17, 2012 at 10:59 PM, Hans Milling <hm at geograf.dk> wrote:
> I already tried this, the tiles are then re-generated overwriting the
> existing ones even though they are identical. It's like the mapguide server
> has some internal table of tiles generated (perhaps in the repository) and
> this is wiped when you change the map.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Change-map-coordinate-system-without-regenerating-tiles-tp5009234p5009278.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
