[mapguide-users] Tool Tip will not display with Bing Hybrid as default base layer
elliott17
elliottd at ae.ca
Fri Oct 19 13:25:56 PDT 2012
I am running MGOS 2.2 and fusion on Server 2008.
Within my fusion site, if I create a layout with BING street map as the
default layer (visible at load time), my tool tips work. The tool tips also
work if I change between street map, satellite and hybrid.
If I edit my layout to have satellite or hybrid as the default layer
(visible at load time), the tool tips will not show up.
Anyone come across this?
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Tool-Tip-will-not-display-with-Bing-Hybrid-as-default-base-layer-tp5009964.html
