[mapguide-users] http://localhost/Default.aspx/localized/en.json when trying to add asp.net to mobileviewer
Wilson Herrera wherrera at pccadpanama.com
Sat Oct 20 18:43:14 PDT 2012
Hi Gordon.
before anything, thank you for your help.
I did changed the values for the basemaps and the mapdef as you sugested,
but the error keeps appearing.
tracing the error in firebug, and web console, i can see that this function
var locale = mobileViewer.getQueryParam('locale');
        if(locale != null && locale.length > 0)
            options.locale = locale;
is searching in this url
[20:37:21.582] GET http://localhost/Default.aspx/localized/es.json [HTTP/1.1
404 Not Found 2ms]
where instead of Default.aspx, should be the name of the folder (Mobile).
i tried to modify this parameter without success, in this way:
var locale = Mobile/localized/es.json
the POST data appears fine in the page, but this seems the only hurdle left
to overcome.
View this message in context: http://osgeo-org.1560.n6.nabble.com/http-localhost-Default-aspx-localized-en-json-when-trying-to-add-asp-net-to-mobileviewer-tp5009109p5010071.html
