[mapguide-users] http://localhost/Default.aspx/localized/en.json when trying to add asp.net to mobileviewer
Wilson Herrera
wherrera at pccadpanama.com
Sat Oct 20 20:56:03 PDT 2012
hello everyone,
wow this was hard as hell.
first, i had to modify this
var locale = "../../mapserver2013/Mobileviewer/localized/en.json?map=<%=map
%>&baselayers=bing,google,osm";
if (locale != null && locale.length > 0) {
options.locale = locale;
afther that, i had to redirect all the calls to mapguide fusion inside the
maobileviewerSF-compressed (yes i did it directly over that file, the
compiling process is still a black box to me) and after that, i was able to
use a POST - able mobile viewer application.
i think i should share this with you people, so i will post the source code
around thursday.
as for the experience, the web console in firefox is really useful sometimes
i got an error and only there it appeared.
thanks gordon, your help was all that i needed to begin to grasp the correct
procedures.
for everyone else, stay tuned for the source code, maybe this will be useful
for someone.
best regards,
Wilson H
View this message in context: http://osgeo-org.1560.n6.nabble.com/http-localhost-Default-aspx-localized-en-json-when-trying-to-add-asp-net-to-mobileviewer-tp5009109p5010079.html
