[mapguide-users] Layer areas not transparent
Zac Spitzer
zac.spitzer at gmail.com
Wed Oct 24 17:50:42 PDT 2012
are you using an image format which supports transparency?
off the top of my head, in 2.2 only PNG does, in 2.4 PNG8 also supports it
On Wed, Oct 24, 2012 at 8:11 PM, Hans Milling <hm at geograf.dk> wrote:
> Hi All
> I am trying to put a MapInfo (TAB) vector layer on a map with some areas
> that should display as transparent. But the layer is not transparent when I
> preview, even though I set both fill colors to 80FF0000 (50% transparent
> red). The layer xml version is 1.3.0.
> I am using MGOS2.2 and Maestro 4.0.3.
> Do I need to set something special on the map or layer before it will render
> transparency?
> Best regards
> Hans Milling...
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Layer-areas-not-transparent-tp5010755.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
