[mapguide-users] Pathing revisited
Jamo adam.jamison at portbris.com.au
Mon Sep 17 18:45:01 PDT 2012
couple of things to check.
1. can you connect to mapguide using maestro.
2. are you using iis or apache?
  2a. if apache perhasp your directories are case sensative ensure
"MapGuide" is actually not "mapguide"
  2b. if iis the port won't be required so just
http://mapguide/test_07/hello.htm
3. is the apache service started in services.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Pathing-revisited-tp5002498p5002499.html
