[mapguide-users] Plotting to DWF
Jonathan Rizzo
jrizzo at Langan.com
Fri Sep 21 08:45:11 PDT 2012
I should amend what I said. I renamed the DWF to be a ZIP file, and I used windows to examine the contents, no problem. I also used 7-zip to test the archive, and it reported no problems. However, when I use 7-Zip to extract the contents of the zip, it says that there is a "Data error in '715941D4-1AC2-4545-8185-BC40E053B551.TYPEINFO'. File is broken
Jonathan Rizzo
Senior Applications Developer
Direct: 201.398.4650
Mobile: 551.206.5782
LANGAN ENGINEERING & ENVIRONMENTAL SERVICES
NEW JERSEY NEW YORK CONNECTICUT PENNSYLVANIA VIRGINIA FLORIDA CALIFORNIA
ABU DHABI ATHENS DOHA DUBAI ISTANBUL
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, September 20, 2012 11:24 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Plotting to DWF
Does the DWF file check firstly check out as a zip file?
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Plotting-to-DWF-tp5003362p5003407.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This electronic transmission may contain confidential, proprietary or privileged information. No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
