[mapguide-users] Multi-User Environment for MapGuide
Stefanie Siegel s.siegel at isb-siegel.de
Wed Sep 26 02:43:14 PDT 2012
Thanks for this fast answer!
5-10 users should be normal case. Up to 20 possible.
The maps vary from data in Oracle Spatial (several GB volume) to ordinary
SHP and TIFF. Performance as single user is so far not bad as soon as there
is a TileCache (still got the MGCooker problem).
Is it possible to substitute MG 2.2 with 2.4 or are there any bigger changes
in settings?
Is there any description available how to set up MG on a cluster of servers?
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
Gesendet: Mittwoch, 26. September 2012 11:34
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Multi-User Environment for MapGuide
given MG 2.4 has 64 bit support, you can scale up on big hardware or run a
cluster of smaller servers, but it all really depends on your maps and how
they perform
MapGuide is inherently multi user, how many users are you looking at?
On Wed, Sep 26, 2012 at 7:30 PM, Stefanie Siegel <s.siegel at isb-siegel.de>
wrote:
> Hi,
> is there any possibility to set up MapGuide with increased performance
> in a multi-user environment?
> Used components: MGOS 2.2, Maestro 4, Windows (Linux in progress),
> together with OpenLayers.
> Right now the whole system is either installed on one Server or
> virtual server.
> Is MGOS capable to be used in a multi-user environment? Are the any
> limits known? What would be min. system requirements?
> Thanks for helping.
> Regards,
> Steffi
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
