[mapguide-users] Multi-User Environment for MapGuide
Martin Morrison
martin.morrison at edsi.com
Wed Sep 26 05:32:43 PDT 2012
This is the key part of Zac's note " but it all really depends on your maps and how they perform".
5-10 users? That is nothing. Seriously, just work on the layers, code, etc to make them as fast as possible then load test it. On your Oracle data, create indexes, spatial indexes, optimize the data layers, e.g don't display 1 ft road segments at a large zoom scale. Try it, you might be pleasantly surprised.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefanie Siegel
Sent: Wednesday, September 26, 2012 5:43 AM
To: 'MapGuide Users Mail List'
Subject: Re: [mapguide-users] Multi-User Environment for MapGuide
Thanks for this fast answer!
5-10 users should be normal case. Up to 20 possible.
The maps vary from data in Oracle Spatial (several GB volume) to ordinary SHP and TIFF. Performance as single user is so far not bad as soon as there is a TileCache (still got the MGCooker problem).
Is it possible to substitute MG 2.2 with 2.4 or are there any bigger changes in settings?
Is there any description available how to set up MG on a cluster of servers?
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
Gesendet: Mittwoch, 26. September 2012 11:34
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Multi-User Environment for MapGuide
given MG 2.4 has 64 bit support, you can scale up on big hardware or run a cluster of smaller servers, but it all really depends on your maps and how they perform
MapGuide is inherently multi user, how many users are you looking at?
On Wed, Sep 26, 2012 at 7:30 PM, Stefanie Siegel <s.siegel at isb-siegel.de>
wrote:
> Hi,
> is there any possibility to set up MapGuide with increased performance
> in a multi-user environment?
> Used components: MGOS 2.2, Maestro 4, Windows (Linux in progress),
> together with OpenLayers.
> Right now the whole system is either installed on one Server or
> virtual server.
> Is MGOS capable to be used in a multi-user environment? Are the any
> limits known? What would be min. system requirements?
> Thanks for helping.
> Regards,
> Steffi
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
