[mapguide-users] Multi-User Environment for MapGuide
Zac Spitzer
zac.spitzer at gmail.com
Wed Sep 26 19:59:14 PDT 2012
one last tip, sqlite is the fastest FDO datasource by a large factor
only keep data which changes regularly in oracle for best performance
On Thu, Sep 27, 2012 at 12:56 PM, Johnnie GIS <johnniegis at gmail.com> wrote:
> Totally agree with this Martin.
> Regards,
> Jonathon McIntyre
> i-Open Technologies
> Twitter: @JohnnieGIS
> www.i-opentech.com
> (C) 778-549-8382
> Sent from my iPhone, please excuse any typos.
> On Sep 26, 2012, at 5:32 AM, Martin Morrison <martin.morrison at edsi.com> wrote:
> This is the key part of Zac's note " but it all really depends on your maps and how they perform".
> 5-10 users? That is nothing. Seriously, just work on the layers, code, etc to make them as fast as possible then load test it. On your Oracle data, create indexes, spatial indexes, optimize the data layers, e.g don't display 1 ft road segments at a large zoom scale. Try it, you might be pleasantly surprised.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefanie Siegel
> Sent: Wednesday, September 26, 2012 5:43 AM
> To: 'MapGuide Users Mail List'
> Subject: Re: [mapguide-users] Multi-User Environment for MapGuide
> Thanks for this fast answer!
> 5-10 users should be normal case. Up to 20 possible.
> The maps vary from data in Oracle Spatial (several GB volume) to ordinary SHP and TIFF. Performance as single user is so far not bad as soon as there is a TileCache (still got the MGCooker problem).
> Is it possible to substitute MG 2.2 with 2.4 or are there any bigger changes in settings?
> Is there any description available how to set up MG on a cluster of servers?
> -----Ursprüngliche Nachricht-----
> Von: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
> Gesendet: Mittwoch, 26. September 2012 11:34
> An: MapGuide Users Mail List
> Betreff: Re: [mapguide-users] Multi-User Environment for MapGuide
> given MG 2.4 has 64 bit support, you can scale up on big hardware or run a cluster of smaller servers, but it all really depends on your maps and how they perform
> MapGuide is inherently multi user, how many users are you looking at?
> On Wed, Sep 26, 2012 at 7:30 PM, Stefanie Siegel <s.siegel at isb-siegel.de>
> wrote:
>> Hi,
>> is there any possibility to set up MapGuide with increased performance
>> in a multi-user environment?
>> Used components: MGOS 2.2, Maestro 4, Windows (Linux in progress),
>> together with OpenLayers.
>> Right now the whole system is either installed on one Server or
>> virtual server.
>> Is MGOS capable to be used in a multi-user environment? Are the any
>> limits known? What would be min. system requirements?
>> Thanks for helping.
>> Regards,
>> Steffi
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> +61 405 847 168
Zac Spitzer
+61 405 847 168
