[mapguide-users] Refresh Layer Properties in Maestro
Gabriele Monfardini
gabrimonfa at gmail.com
Thu Sep 27 01:24:30 PDT 2012
> Using Maestro (I'm using 4.0.3), is it possible to refresh the Layer
> Properties (feature class) of a layer without having to remove the layer and
> add it again?
> I have an issue where a database has changed over time. I can remove and add
> the feature source to refresh the feature classes (getting new tables in the
> list), but the task to refresh the layer properties is painful.
You may try to purge cached schema information.
It will force Maestro to examine again the schema of the db and it
will find schema changes.
After that, if I undestand correctly your issue, reopening the layer
should show you current properties.
Regards,
Gabriele Monfardini
