[mapguide-users] Draw polygon in Mapguide using Asp.net
A H
hizperion at hotmail.com
Fri Sep 28 00:12:28 PDT 2012
since i can't find way to edit the vertex using built-in function, i decided
to allow user to draw multiple polygons. the selected polygons can later be
used to be combined, or clear polygons that it overlaps with.
here's the sample code:
<html>
<head>
</head>
<body class="AppFrame" onLoad="InitDocument()">
bool mapUpdated = false;
string returnStat = "";
string mgSessionId = GetParameters()["SESSION"];
Uri MyUrl = Request.Url;
Response.Write("URL: " + MyUrl.AbsoluteUri+ "<br><br>");
try
string selXml = GetParameters()["selXml"];
string selCmd = GetParameters()["command"];
Response.Write(selCmd + "<br>");
Response.Write(selXml);
if(selCmd=="remove")
ClearPolygon(selXml, mgSessionId);
if(selCmd=="combine")
returnStat = CombinePolygon(selXml, mgSessionId);
if(selCmd=="removeall")
ClearPolygon(mgSessionId);
if(selCmd=="combineall")
returnStat = CombinePolygon(mgSessionId);
if(returnStat=="")
mapUpdated = true;
catch (MgException mge)
Response.Write(mge.GetExceptionMessage());
Response.Write(mge.GetDetails());
</body>
</html>
<script language="c#" runat="server">
void ClearPolygon(string mgSessionId)
Clear("ID > 0", mgSessionId);
void ClearPolygon(string selectionXml, string mgSessionId)
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgMap map = new MgMap(siteConnection);
map.Open(WORLD_MAP);
MgLayer polyLayer = GetLayerByName(map, "PolyMarker");
MgSelection selection = new MgSelection (map, selectionXml);
Clear(selection.GenerateFilter(polyLayer,"PolyMarker"), mgSessionId);
void Clear(string selectionFilter, string mgSessionId)
try
InitializeWebTier ();
MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
MgFeatureService featureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
MgResourceIdentifier FeatureSourceId = new MgResourceIdentifier("Session:"
+ mgSessionId + "//PolyMarker.FeatureSource");
MgFeatureCommandCollection Commands = new MgFeatureCommandCollection();
if (polyLayer != null)
Response.Write("<br/>" + selectionFilter);
Commands.Add(new MgDeleteFeatures("PolyMarker", selectionFilter));
//featureService.UpdateFeatures(FeatureSourceId, Commands, false);
ReleaseReader(featureService.UpdateFeatures(FeatureSourceId, Commands,
false), Commands);
polyLayer.SetVisible(true);
polyLayer.ForceRefresh();
map.Save(resourceService);
string CombinePolygon(string mgSessionId)
return Combine("ID > 0", mgSessionId);
string CombinePolygon(string selectionXml, string mgSessionId)
return Combine(selection.GenerateFilter(polyLayer,"PolyMarker"),
mgSessionId);
string Combine(string selectionFilter,string mgSessionId)
bool flag = true;
DateTime startTime = DateTime.Now;
try
MgResourceService;
MgFeatureService;
MgFeatureQueryOptions selQuery = new MgFeatureQueryOptions();
selQuery.SetFilter(selectionFilter);
MgFeatureReader featureReader = polyLayer.SelectFeatures(selQuery);
MgGeometryCollection geometries = new MgGeometryCollection();
MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
MgGeometryFactory geometryFactory = new MgGeometryFactory();
MgPolygon newPolygon;
while(featureReader.ReadNext())
MgByteReader temp = featureReader.GetGeometry("GEOM");
MgGeometry tempGeo = geometryReaderWriter.Read(temp);
geometries.Add(tempGeo);
for(int i=0; i<geometries.GetCount(); i++) // check if geometries
intersects with each other
bool onceIntersect = false;
for(int j=0; j<geometries.GetCount(); j++)
if(i!=j)
if(geometries.GetItem(i).Intersects(geometries.GetItem(j)))
onceIntersect = true;
if(!onceIntersect)
flag = false;
return "Not all polygon intersects with each other";
if(flag)
MgGeometry newGeometry = geometries.GetItem(0);
for(int i=1; i<geometries.GetCount(); i++) // combine the geometries
newGeometry = newGeometry.Union(geometries.GetItem(i));
MgByteReader geom = geometryReaderWriter.Write(newGeometry);
MgPropertyCollection properties = new MgPropertyCollection();
properties.Add(new MgGeometryProperty("GEOM", geom));
properties.Add(new MgStringProperty("Text", ""));
Commands.Add(new MgInsertFeatures("PolyMarker", properties));
false), Commands);
return "";
View this message in context: http://osgeo-org.1560.n6.nabble.com/Edit-polygon-tp4183861p5005108.html
