[mapguide-users] Problems with WMS - queryable layer
martind
martin.dagan.work at gmail.com
Thu Apr 11 09:24:27 PDT 2013
Hi there,
I have some problems with publishing WMS service from MapGuide 2.5.
When I do the Get Capabilities, I have this:
I tick queryable in the WMS properties in MapGuide Maestro but it is not
taken into account. Why?
Other problem, I have this under "Layer":
And this under :
Why is there this EPSG:4326? Is it a default value? Why not 3857? All the
features I have are in 3857.
At last, when I try to see the WMS layer with ArcMap or QGIS, nothing is
displayed. The properties of the layer are correctly retrieved, though. When
I try to see the WMS layer from the URL
(http://testserver:8008/mapguide/mapagent/mapagent.fcgi?REQUEST=GETMAP&SERVICE=WMS&VERSION=1.3.0&FORMAT=image%2Fpng&LAYERS=E-Ways%2F1_Data%2Fe-Waterways%2FLayers%2FEWW_layer&BBOX=-1108015.99542867%2C4295808.79330998%2C6314363.9597%2C9239804.5618&SRS=EPSG%3A3857&WIDTH=1000&HEIGHT=700&BGCOLOR=0x0000FF&TRANSPARENT=TRUE),
it works.
In QGIS, the WMS service properies says this:
Is it normal that I have still "localhost"? It should use the server name
instead, shouldn't it? (QGIS is installed on another computer).
Thank you for your help if possible :-)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-WMS-queryable-layer-tp5046150.html
