[mapguide-users] Problems with WMS - queryable layer
Jackie Ng jumpinjackie at gmail.com
Thu Apr 11 09:36:03 PDT 2013
If queryable does not change to 1 after you tick in in Maestro, it's probably
a bug in Maestro.
localhost:8008 is the default WFS/WMS server name/port configuration value
that the installer does not currently update based on your installer
choices. So you have to change this value in the MapGuide Site Administrator
to match your server name/ip/port
I don't quite understand the EPSG:4326 problem, can you describe in detail
what you did and what you expected?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-WMS-queryable-layer-tp5046150p5046157.html
