[mapguide-users] 64-bit woes
Jackie Ng jumpinjackie at gmail.com
Thu Apr 11 09:54:19 PDT 2013
You cannot debug 64-bit ASP.net MapGuide applications through the built-in VS
web server as that is a 32-bit application.
This is the default choice for ASP.net applications. You have to debug
though local IIS (it's some project setting in there)
You have to UAC-elevate VS in order to debug with local IIS.
And yes you should not use any CPU but the arch that matches the bit ness of
your MapGuide installation.
I also don't understand how MapGuideDotNetApi is still referenced. The
assemblies have been split for quite some time.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5046160.html
