[mapguide-users] 64-bit woes
Greg
gbneff at cid.utah.gov
Thu Apr 25 09:05:22 PDT 2013
I am suddenly getting the following error when I build my project using
Jackie's nuget package and don't know what to make of it:
The command "
xcopy /s /y "C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-base-x64.2.5.0.7449\mapguide-api-base\*.*"
"C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\"
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-web-x64.2.5.0.7449\mapguide-api-web\*.*"
"C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\"" exited with code 4.
I uninstalled and re-installed the package just to be sure and still have
the error.
I am also getting this warning below again, but as long as I keep all my c#
code in the CodeBehind and not on the .aspx page, Intellisense works:
C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\Cid_Map.aspx: ASP.NET
runtime error: Could not load file or assembly 'Cid_Map' or one of its
dependencies. An attempt was made to load a program with an incorrect
format. C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\Cid_Map.aspx
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5049674.html
