[mapguide-users] 64-bit woes
Jackie Ng jumpinjackie at gmail.com
Thu Apr 25 21:00:27 PDT 2013
If you're debugging using the built-in web server, stop.
That web server is a 32-bit process that *cannot* run 64-bit ASP.net
applications.
If you want to debug a 64-bit ASP.net web application, it has to be through
local IIS, which normally means you have to run Visual Studio as an
Administrator.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5049790.html
