[mapguide-users] 64-bit woes
    Greg
    gbneff at cid.utah.gov
    Fri Apr 26 07:27:29 PDT 2013
I am using the local IIS Web server for debug.  I am running vs as
administrator.  I must be doing something else wrong.  My build and
Intellisense outputs are below.  Is it possible that some of my other
project references are causing a problem?
/----- Build started: Project: Cid_Map, Configuration: Debug Any CPU ------
  Cid_Map -> C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\Cid_Map.dll
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-base-x64.2.5.0.7449\mapguide-api-base\ACE.dll
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-base-x64.2.5.0.7449\mapguide-api-base\FoundationUnmanagedApi.dll
  Sharing violation
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-web-x64.2.5.0.7449\mapguide-api-web\lib_json.dll
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-web-x64.2.5.0.7449\mapguide-api-web\MapGuideCommonUnmanagedApi.dll
  Sharing violation/
 Intellisense Output:
/There was a problem reading metadata from 'C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\xerces-c_3_1mg.dll' ('An attempt
was made to load a program with an incorrect format.'). IntelliSense may not
work properly until the solution is reloaded.
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\WebUnmanagedApi.dll' ('An attempt
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgPlatformBase.dll' ('An attempt
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgFoundation.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\GeometryUnmanagedApi.dll' ('An
attempt was made to load a program with an incorrect format.'). IntelliSense
may not work properly until the solution is reloaded.
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgHttpHandler.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgGeometry.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\PlatformBaseUnmanagedApi.dll' ('An
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgWebApp.dll' ('An attempt was made
to load a program with an incorrect format.'). IntelliSense may not work
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MapGuideCommonUnmanagedApi.dll'
('An attempt was made to load a program with an incorrect format.').
IntelliSense may not work properly until the solution is reloaded.
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgWebSupport.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\FoundationUnmanagedApi.dll' ('An
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgMdfModel.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgMdfParser.dll' ('An attempt was
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\MgMapGuideCommon.dll' ('An attempt
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\ACE.dll' ('An attempt was made to
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\lib_json.dll' ('An attempt was made
Files\OSGeo\MapGuide\Web\www\Cid_Map\Bin\GEOS.dll' ('An attempt was made to
properly until the solution is reloaded./
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5049913.html
