[mapguide-users] 64-bit woes
Greg gbneff at cid.utah.gov
Fri Apr 26 08:39:09 PDT 2013
I have additional information:
I changed the platform target in my project from x64 to any cpu and my
IntelliSense problems went away.
I still get the build error when the dll files are copied from the nuget
packages (see below).  If I stop the local IIS server during build, the
error goes away.  I can easily work around this.
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-base-x64.2.5.0.7449\mapguide-api-base\ACE.dll
  Sharing violation
  C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-web-x64.2.5.0.7449\mapguide-api-web\lib_json.dll
  Sharing violation
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(4264,5):
error MSB3073: The command "
error MSB3073: xcopy /s /y "C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-base-x64.2.5.0.7449\mapguide-api-base\*.*"
"C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\"
Files\OSGeo\MapGuide\Web\www\Cid_Map\packages\mapguide-api-web-x64.2.5.0.7449\mapguide-api-web\*.*"
"C:\Program Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\"" exited with code 4.
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5049930.html
