[mapguide-users] Map Menu, i can't pan after select an another map
renardchan emailvalide at yahoo.fr
Mon Aug 5 01:31:47 PDT 2013
Thanks for the answer.
Some people seem to have the same problem
http://osgeo-org.1560.x6.nabble.com/Fusion-doesn-t-sync-the-two-Maps-td5056897.html#a5057133.
Below it's what's i test.
1) Two maps with the same vector layer in EPSG 3857 and same extents. In
application definition, the two maps havn't commercial Map Service layers.
==> Map Menu works well
2)Two maps with the same vector layer in EPSG 3857 and same extents. The
second map have a commercial Map Service layers.
First  I switch to the second maps with the commercial vector layer ==> work
well but i'm not in the same coordinate.
Second i come back to the initial map ==> here i can't pan.
3)Two maps with the same vector layer in EPSG 3857 and same extents. Two
maps have commercial map service. First change ==> i can't pan.
So my problem seem to become from my maps who have commercial map service.
Moreover my layers seems to have translation on the overview map.
I check the coordinate system of my maps and vector layers. It's
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
Tanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-Menu-i-can-t-pan-after-select-an-another-map-tp5070445p5070778.html
