[mapguide-users] MapGuide 2.5 - Fusion - Measurement unit undefinable
Benjamin Zaugg b.zaugg at rudaz.ch
Mon Aug 5 05:36:34 PDT 2013
Hi Torrini
I had the same Problem. The solution was to remove the following code from
fusionSF-compressed.js or fusionSF.js:
if(o.wkt&&o.wkt.length>0){wktProj=new OpenLayers.Projection(o.wkt)}else
Then it worked properly.
Best, Benjamin
2013/8/5 torrini <maria.kallbach at geoplanteam.ch>
> Hi list,
> the units in my measurement widget is undefinable. I know I can set the
> unit
> to imperial/degree/meter, but I can't fix my problem.
> I made a comparison measurement in AJAX-Viewer. A distance in AJAX with
> 0.33
> km has a length of 4'055'226 m (approximately :-)).
> Has anybody a clue where this colossal unit come from? Is there a parameter
> I changed accidentally?
> Thanks in advance!
> -torrini
> AJAX measurement (for a larger view: right-click --> show image):
> <http://osgeo-org.1560.x6.nabble.com/file/n5070804/ajax.png>
> fusion measurement (for a larger view: right-click --> show image):
> <http://osgeo-org.1560.x6.nabble.com/file/n5070804/fusion.png>
> http://osgeo-org.1560.x6.nabble.com/MapGuide-2-5-Fusion-Measurement-unit-undefinable-tp5070804.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130805/25da52d1/attachment.html>
