[mapguide-users] GDAL - MapImage with stripes
Zac Spitzer zac.spitzer at gmail.com
Tue Aug 6 17:58:13 PDT 2013
look at your track comments, looks like it might just be a case of needing
to use Ceiling rather than a Floor?
On Wed, Aug 7, 2013 at 1:16 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> It would be nice if someone could explain in greater detail what the
> MaxRasterImageHeight and MaxRasterImageWidth properties in serverconfig.ini
> are actually supposed to do.
> From my own tests thus far, I've found that as long as MaxRasterImageHeight
> and MaxRasterImageWidth are less than or equal to the display size of your
> GetMapImage request, the striped effect does not happen.
> If you go one pixel over, then the striped effect occurs.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/GDAL-MapImage-with-stripes-tp5016254p5071093.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130807/bec2d3b5/attachment.html>
