[mapguide-users] consuming WMS from ArcGIS server in MGOS2.5
telekater emiel.kater at gmail.com
Tue Aug 13 03:26:15 PDT 2013
I tried that, but when I click the Advanced button Maestro gives an error:
Message: Object reference not set to an instance of an object
(details in attachment: error5.txt)
Emiel
2013/8/13 Jackie Ng [via OSGeo.org] <ml-node+s1560n5072214h15 at n6.nabble.com>
> The "Advanced" button in the Maestro WMS Feature Source editor builds this
> document for you through a user interface so you don't have to edit the XML
> document by hand.
> - Jackie
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/consuming-WMS-from-ArcGIS-server-in-MGOS2-5-tp5068542p5072214.html
>  To unsubscribe from consuming WMS from ArcGIS server in MGOS2.5, click
> here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5068542&code=ZW1pZWwua2F0ZXJAZ21haWwuY29tfDUwNjg1NDJ8ODE3Mjk4ODIy>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
error5.txt (1K) <http://osgeo-org.1560.x6.nabble.com/attachment/5072249/0/error5.txt>
View this message in context: http://osgeo-org.1560.x6.nabble.com/consuming-WMS-from-ArcGIS-server-in-MGOS2-5-tp5068542p5072249.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130813/d654430c/attachment.html>
