[mapguide-users] consuming WMS from ArcGIS server in MGOS2.5
Berg, James
James.Berg at stantec.com
Tue Aug 13 10:17:47 PDT 2013
When I get those errors clicking the Advanced button for a WMS feature source it’s because the server doesn’t exist or I entered the URL string wrong. Maestro should be able to at least see the service if it exists. Also, your get capabilities url isn’t working for me, by the way. If you can load the WMS into another kind of application like ArcGIS or something you can at least rule out the possibility of the service just plain not working.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of telekater
Sent: Tuesday, August 13, 2013 5:26 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] consuming WMS from ArcGIS server in MGOS2.5
I tried that, but when I click the Advanced button Maestro gives an error:
Message: Object reference not set to an instance of an object
(details in attachment: error5.txt)
Emiel
2013/8/13 Jackie Ng [via OSGeo.org] <[hidden email]</user/SendEmail.jtp?type=node&node=5072249&i=0>>
The "Advanced" button in the Maestro WMS Feature Source editor builds this document for you through a user interface so you don't have to edit the XML document by hand.
- Jackie
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/consuming-WMS-from-ArcGIS-server-in-MGOS2-5-tp5068542p5072214.html
To unsubscribe from consuming WMS from ArcGIS server in MGOS2.5, click here.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
[cid:~WRD000.jpg]error5.txt (1K) Download Attachment<http://osgeo-org.1560.x6.nabble.com/attachment/5072249/0/error5.txt>
View this message in context: Re: consuming WMS from ArcGIS server in MGOS2.5<http://osgeo-org.1560.x6.nabble.com/consuming-WMS-from-ArcGIS-server-in-MGOS2-5-tp5068542p5072249.html>
Sent from the MapGuide Users mailing list archive<http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130813/e2d1e850/attachment.html>
Type: image/jpeg
Desc: ~WRD000.jpg
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130813/e2d1e850/attachment.jpg>
