[mapguide-users] Map frame display delay
Jackie Ng
jumpinjackie at gmail.com
Sun Aug 18 21:41:34 PDT 2013
PreCacheMaps effectively does a MgMap.Create() on each Map Definition
specified, thus pre-caching any associated Feature Sources, Schemas, Class
Definitions and Spatial Contexts needed by the MgMap.Create() call.
See:
http://themapguyde.blogspot.com.au/2012/10/mapguide-server-cache-priming.html
All cached objects are timestamped (at the time they are retrieved), and
CacheTimeLimit is what a regularly-scheduled function in MapGuide uses to
check for which cached items need to be removed. The logic being: Remove any
cached object that has not been accessed for <CacheTimeLimit> or more
seconds.
So I think that bumping up that number should indeed do the trick.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-frame-display-delay-tp5072746p5073064.html
