[mapguide-users] Map frame display delay
Zac Spitzer zac.spitzer at gmail.com
Sun Aug 18 22:17:30 PDT 2013
I have seen this as well, there are some long delays in the mapguide
service starting,
often seen after a reboot with auto start (the default) set, startup takes
soooo long
the service fails to start...
http://osgeo-org.1560.x6.nabble.com/Widespread-service-auto-startup-problems-on-windows-td5057973.html
On Mon, Aug 19, 2013 at 2:41 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> PreCacheMaps effectively does a MgMap.Create() on each Map Definition
> specified, thus pre-caching any associated Feature Sources, Schemas, Class
> Definitions and Spatial Contexts needed by the MgMap.Create() call.
> See:
> http://themapguyde.blogspot.com.au/2012/10/mapguide-server-cache-priming.html
> All cached objects are timestamped (at the time they are retrieved), and
> CacheTimeLimit is what a regularly-scheduled function in MapGuide uses to
> check for which cached items need to be removed. The logic being: Remove
> any
> cached object that has not been accessed for <CacheTimeLimit> or more
> seconds.
> So I think that bumping up that number should indeed do the trick.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Map-frame-display-delay-tp5072746p5073064.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130819/bb092271/attachment.html>
