[mapguide-users] Reproject-on-the-fly
Steve G
stevenlgolden at gmail.com
Tue Aug 27 11:53:05 PDT 2013
I think you are asking if you can re-project on the fly using MGOS as the WMS
server/provider, but just to clarify, are you using MGOS as the WMS
server/provider, or are you consuming WMS layers from another application?
I think some WMS servers can potentially support different coordinate
systems for each layer/sub-layer, but I don't think this is the case with
MGOS (somebody can correct me if I am wrong). On the flip side, your
application consuming the WMS layer should be the one re-projecting the
layer as is the case with MGOS. That is what Jackie is pointing out if you
set up a Map Definition that contains a WMS layer (as long as the WMS layer
coordinate system is supported in MGOS).
-Steve G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Reproject-on-the-fly-tp5074540p5074608.html
