[mapguide-users] Reproject-on-the-fly
Andrey Maraev
asmaraev at gmail.com
Tue Aug 27 23:22:04 PDT 2013
Thanx guys!
I'm using MGOS as the WMS server/provider and I do not use MapDefinition as
WMS because I have no idea how to do it
2013/8/27 Steve G <stevenlgolden at gmail.com>
> I think you are asking if you can re-project on the fly using MGOS as the
> WMS
> server/provider, but just to clarify, are you using MGOS as the WMS
> server/provider, or are you consuming WMS layers from another application?
> I think some WMS servers can potentially support different coordinate
> systems for each layer/sub-layer, but I don't think this is the case with
> MGOS (somebody can correct me if I am wrong). On the flip side, your
> application consuming the WMS layer should be the one re-projecting the
> layer as is the case with MGOS. That is what Jackie is pointing out if you
> set up a Map Definition that contains a WMS layer (as long as the WMS layer
> coordinate system is supported in MGOS).
> -Steve G
> http://osgeo-org.1560.x6.nabble.com/Reproject-on-the-fly-tp5074540p5074608.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
lernen,lernen und lernen
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130828/463e8eaf/attachment.html>
