[mapguide-users] local connection
mika at digikartta.net mika at digikartta.net
Mon Dec 9 21:01:24 PST 2013
Maybe I should try that now with an invalid filter and while wrapped
with try and catch, see if the exception is thrown properly. Peculiar
thing is that the exception concerning the non-existing attribute was
thrown much later when calling resource saving..
Yep, the OR-filter would be better although there are only a little
number of ids, often only couple and rows with the same id can be many -
it is a type id.
- mika -
Jackie Ng kirjoitti 2013-12-10 04:50:
> If you delete with an invalid filter, the FDO provider would (and
> should)
> throw an exception to indicate this.
> Also, rather than execute individual deletes for each id, you could
> chain
> those ids together into a single filter with multiple logical ORs or
> if the
> provider supports it, use an IN filter
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/local-connection-tp5091886p5093446.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
