[mapguide-users] local connection
mika at digikartta.net
Mon Dec 9 23:10:24 PST 2013
Yep,
I can confirm that this method with invalid filter won't throw an
exception but much later on the layerdefinition (with same datasource
path) will do it.
public void ClearDataSource(IServerConnection conn, String
dataSourceId, String featureName, string idField, List<int> laiteidt)
foreach (int laiteid in laiteidt)
com.IDeleteFeatures deleteCmd =
(com.IDeleteFeatures)conn.CreateCommand((int)OSGeo.MapGuide.MaestroAPI.Commands.CommandType.DeleteFeatures);
deleteCmd.FeatureSourceId = dataSourceId;
deleteCmd.ClassName = featureName;
//deleteCmd.Filter = idField + "=" + laiteid;
deleteCmd.Filter = "ID>=0";
try
int nDeleted = deleteCmd.Execute();
catch (Exception ex)
throw ex;
A good hundred lines after:
mg.resSrvc.SetResourceXmlData(layerDef, layerDefContent);
<2013-12-10T09:01:28> 4220 Administrator
Error: Failed to retrieve message for "MgFeatureServiceException".
An exception occurred in FDO component.
The identifier 'ID' was not recognized. (Cause: , Root Cause:
The identifier 'ID' was not recognized. )
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
f:\build\ims2014_knight\build_76.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpUpdateFeatures.Execute line 143 file
f:\build\ims2014_knight\build_76.1\ent\os\server\src\services\feature\OpUpdateFeatures.cpp
This obviously refers to the ClearDataSource method, not to the
SetResourceXmlData()..
How on earth this can be like that? FDO is OSGeo.SDF. Any idea?
- mika -
P.S: I guess the execute() method will return -1 if something goes
wrong. That could be used for "catching the exception"..?
mika at digikartta.net kirjoitti 2013-12-10 07:01:
> Maybe I should try that now with an invalid filter and while wrapped
> with try and catch, see if the exception is thrown properly. Peculiar
> thing is that the exception concerning the non-existing attribute was
> thrown much later when calling resource saving..
> Yep, the OR-filter would be better although there are only a little
> number of ids, often only couple and rows with the same id can be
> many
> - it is a type id.
> - mika -
> Jackie Ng kirjoitti 2013-12-10 04:50:
>> If you delete with an invalid filter, the FDO provider would (and
>> should)
>> throw an exception to indicate this.
>> Also, rather than execute individual deletes for each id, you could
>> chain
>> those ids together into a single filter with multiple logical ORs or
>> if the
>> provider supports it, use an IN filter
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/local-connection-tp5091886p5093446.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
