[mapguide-users] Bug? - Styling point data using Map Space with WGS84.PseudoMercator
JamesDudden jamesdudden at blueyonder.co.uk
Mon Dec 16 03:37:56 PST 2013
I figured it out - because the map is based on the WGS84 coordinate system it
is converting the X/Y in to its own unit which is totally inaccurate.
Looking at the bottom-left corner where it displays the X/Y current
coordinates the value visible here says it's in metres but it's not.  It
works out to be about .6 of a metre.
I understand that I'm in a different coordinate system but surely 1 metre is
1 metre no matter how you look at it!?
RegardsJD
Software-Matters
View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-Styling-point-data-using-Map-Space-with-WGS84-PseudoMercator-tp5094121p5094440.html
