[mapguide-users] Java memory leak
Riccardo Pucci riccardo.pucci at dbcaditaly.com
Fri Dec 20 06:30:33 PST 2013
I have a mapguide project running in a linux environment using the java
api. After the user's load is increased from 10 users to about 150, we
are continuously getting out of memory errors.
I've seen that java api had suffered memory leaks problems, we are using
AIMS 2013 sp1, is it possible that also this version is affected? If
answer is yes, can AIMS 2014 resolve ours problem?
Thanks
Riccardo
