[mapguide-users] specification of TileCache
Stefanie Siegel
s.siegel at isb-siegel.de
Wed Feb 6 00:14:30 PST 2013
Thanks -that might do the trick.
I tried both methods but didn't change "meters per unit" when using the
official method (was 1)... . Therefore the result is likely to be wrong.
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jackie Ng
Gesendet: Mittwoch, 6. Februar 2013 09:07
An: mapguide-users at lists.osgeo.org
Betreff: Re: [mapguide-users] specification of TileCache
Are you using the official method?
The non-official method of tile generation is known to be imperfect and
inaccurate and getting it fixed will be hard because I have no idea how this
tile generation algorithm works.
If you're not using the official method because you don't know what value to
put in for "meters per unit" in MgCooker, use this PHP script to calculate
it for you:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/PHP/MPUCalculator
- Jackie
View this message in context:
http://osgeo-org.1560.n6.nabble.com/specification-of-TileCache-tp5032364p503
2394.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
