[mapguide-users] Fusion Theme Widget
elliott17
elliottd at ae.ca
Fri Feb 8 08:32:17 PST 2013
I am using MGOS 2.2 on IIS 7 and have a Fusion site. My layers are pulled
from SQL Server 2008. When I use the Theme widget, nothing changes.
I have edited the thememain.php to have:
var session = "<%= GetParameter(args, "SESSION") %>";
var mapName = "<%= GetParameter(args, "MAPNAME") %>";
When I run Theme, the layer properties are not populated.
Do I need to edit GETLAYERINFO?
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-Theme-Widget-tp5033117.html
