[mapguide-users] Fusion Theme Widget
Zac Spitzer zac.spitzer at gmail.com
Sun Feb 10 18:37:54 PST 2013
any errors in the webserver logs/mapguide logs/firebug?
I would highly recommend upgrading to 2.4
z
On Sat, Feb 9, 2013 at 3:32 AM, elliott17 <elliottd at ae.ca> wrote:
> I am using MGOS 2.2 on IIS 7 and have a Fusion site. My layers are pulled
> from SQL Server 2008. When I use the Theme widget, nothing changes.
> I have edited the thememain.php to have:
>         var session = "<%= GetParameter(args, "SESSION") %>";
>         var mapName = "<%= GetParameter(args, "MAPNAME") %>";
> When I run Theme, the layer properties are not populated.
> Do I need to edit GETLAYERINFO?
> Thanks.
> http://osgeo-org.1560.n6.nabble.com/Fusion-Theme-Widget-tp5033117.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130211/cfa78411/attachment.html>
