[mapguide-users] authentication II
Juanita Juanita581 at riseup.net
Wed Jan 2 12:03:59 PST 2013
On 2013-01-02 19:33, GordonL [via OSGeo.org] wrote:
> Are you using Microsoft IIS?  If so, check permissions.
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025340.html
> To unsubscribe from authentication II, click here
> <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5025338&code=SnVhbml0YTU4MUByaXNldXAubmV0fDUwMjUzMzh8MzU4OTE3MjQx>.
> NAML
> <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
No I'm using MG 2.4 , Maestro 5b, Apache from installer. Gordon I'll be
thankful if You could check on your system, the authentication on
similar address:
http://<your_host>:8008/mapguide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Library://Layouts/<your
<http://%3cyour_host%3e:8008/mapguide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Library://Layouts/%3cyour>
name application>.ApplicationDefinition&locale=en
I haven't got anything just loaded the map on template but I need
authentication
required
View this message in context: http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025352.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130102/b6739ab4/attachment.html>
