[mapguide-users] authentication II
Martin Morrison martin.morrison at edsi.com
Wed Jan 2 17:29:30 PST 2013
 Put "&user=Anonymous"  (might be username=) at the end of your url...
Martin
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] on behalf of Juanita [Juanita581 at riseup.net]
Sent: Wednesday, January 02, 2013 3:03 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] authentication II
On 2013-01-02 19:33, GordonL [via OSGeo.org] wrote:
Are you using Microsoft IIS?  If so, check permissions.
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025340.html
To unsubscribe from authentication II, click here<UrlBlockedError.aspx>.
NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
No I'm using MG 2.4 , Maestro 5b, Apache from installer. Gordon I’ll be thankful if You could check on your system, the authentication on similar address:
http://<your_host>:8008/mapguide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Library://Layouts/<your<UrlBlockedError.aspx> name application>.ApplicationDefinition&locale=en
I haven’t got anything just loaded the map on template but I need authentication
required
View this message in context: Re: authentication II<http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5025352.html>
Sent from the MapGuide Users mailing list archive<http://osgeo-org.1560.n6.nabble.com/MapGuide-Users-f4182607.html> at Nabble.com.
